206 - fan not cutting in?
Harlequin
x 23
Unread post by Harlequin »
heya , my friends car has a problem - the fan isn't coming on!
its a 56 reg pug 206 , 1.4 petrol. she says the thermo sensor has been changed. any idea`s?
Simon
Gibbo_Wirral
Re: 206 - fan not cutting in?
Unread post by Gibbo_Wirral »
Some more information about driving conditions might help. My fan hasn't come on for ages, but then I'm never stuck in traffic.
Peugeot Planet Diagnostics: Wirral, Merseyside, Lancashire, Cheshire, North Wales
Harlequin
x 23
pressing the aircon buttons doesn't start the fan spiunning (which it does on my synergie) - maybe a switch or relay?
Simon
BX
x 19
Unread post by BX »
Check the fan to make sure it turns freely and is not seized. A seized fan isn't unusual on a 206.
praxibetel
x 5
Unread post by praxibetel »
Had a similar problem on my old 206 HDi, except the air con did spin up the fans. Took the front panels off to find the fan relays themselves were fine, but some of the wires were completely corroded to the point where they had become tubes of copper oxide. Fixed up the wiring to the relays and it clicked on fine, so that might be something to consider.
406 2.0 HDi - with 150 hp remap from HDi-Tuning
Harlequin
x 23
thank you all - yes the fan did turn , and replacing the relay fixed it all!
thank you all for the davice
Simon
BX
x 19
Unread post by BX »
Glad you got sorted and thanks for letting us know what the problem was. This information could be of use to someone else.
