Load lever sensor - Xantia 1,9TD -00
Albireo
Unread post by Albireo »
Hello!
I wonder how to know if the "load lever sensor" works properly.
Someone said that it functions as a potentiometer with three outputs, so I made seven measurements on the two I have.
Have tried sketching the plug to the "load lever sensor"
== ... 1 .. 2 .. 3 .. . ==
Measurements were made at three positions
- 0% (idle)
- about 50% where the vacuum bellows (in don't know the name) begins to take.
- 100% (full throttle)
Load lever sensor 1
Pin 1-3 .: 1,8k?
Pin 1-2 ----- 0% .: 2,3k?
Pin 1-2 ---- 50% .: 2,2k?
Pin 1-2 --- 100% .: 1,8k?
Pin 2-3 ----- 0% .: 1,3k?
Pin 2-3 ---- 50% .: 1,5k?
Pin 2-3 --- 100% .: 1,8k?
Load lever sensor 2
Pin 1-3 .: 1,8k?
Pin 1-2 ----- 0% .: 4,4k?
Pin 1-2 ---- 50% .: 2,4k?
Pin 1-2 --- 100% .: 1,9k?
Pin 2-3 ----- 0% .: 6,3k?
Pin 2-3 ---- 50% .: 1,6k?
Pin 2-3 --- 100% .: 2,0k?
The resistance can easy be adjusted back and forth. However, understand that it should not be done unnecessarily.
In the Haynes repair manual for Xantia -93-98 stand it. "Although load lever sensor can be individually removed, Citroën test equipment is required to adjust the sensor position when refitting. Any removal and refitting of this component should therefore be entrusted to a Citroën dealer"
Can anyone say why?
What tools are needed to set this sensor?
Have sensors above, resistance values ??that will work?
___________________________________________________________________
It is a sensor from BOSCH
1 467 217 ... (three dots), and in another place there are three digits.: 339
I don't know if the entire part number is .: 1 467 217 339
or whether one should interpret this in another way.
//Jan
