Hi I'm new to this any help would be most welcome I've have got a 2004 boxer the cam belt snapped so I changed the broken rockers and put a new water pump on and timing belt kit. The engine turns over by hand fine. But when I went to start it there was nothing and the engine light is on. I've checked the starter motor and that is fine.
Thanks for any help
boxer not turning over
- x 1240
Re: boxer not turning over
Check the battery voltage with the starter engaged, if its not dropping substantially from 12v the starter is not being engaged which could be an ignition switch or immobiliser fault, if the voltage drops to nothing either the battery is u/s or there is a wiring fault.
zacharyj
Thank you ill check tomorrow I wasn't sure if there might be an earth problem or if it had a fault code that would need taking off
- x 1056
The immobiliser on this van doesent stop the starter turning so its not an immobiliser fault.
The mk1 boxers/relays are common for the braided earth strap between the body & gearbox corroding, not sure if mk2's like yours are the same ? The bolt normally snaps when you try to undo it from the gearbox.
I assume you have checked ALL the fuses ?
- x 1056
Are you getting a cranking feed coming out of the ignition switch ?
- x 1240
Try running a live lead from the battery and touching the small terminal on the starter, if it turns there is a wiring fault, if it doesn't the starter is faulty - assuming the battery and earth connections are OK of course.
zacharyj
I checked the starter motor off the van so I could rule that out. I have just checked the earth lead from the gear box touched it and it come off so hopefully will be that thank you for the help will keep you updated
