Xantia Washer bottle Pump??
Timmo
(Donor 2022)
x 168
Unread post by Timmo »
Evening all,
seems the washer bottle pump has given up on the wagon, are they a specific part or are they a kind of universal thing?? i know i need a twin front and rear pump output, as per this - http://www.ebay.co.uk/itm/131260047809? ... EBIDX%3AIT" onclick="window.open(this.href);return false;
Basically wondering if its worth a trip up the yard and grab one for a couple of quid or pick up the one in the link??
ta muchly in advance,
Timmo.
'58 C2 Code
'58 partner teepee outdoor
VertVega
x 13
Re: Xantia Washer bottle Pump??
Unread post by VertVega »
Here is the washer pump from Xantia Estate MK2. The one in the ebay link looks very similar.
They are same in Xsara as well. When I went to scrap yard to get one, I got the whole
washer bottle, motors and level sensor and for the cost of one washer motor :roll: :)
Before buying motor check that the pipe is not disconnected at the corner joint (body <--> hood).
Timmo
(Donor 2022)
x 168
Thanks matey,
Yeah that was the first port of call! But thought it odd the other day when nothing came out and I didn't smell screenwash when I tried to do the screen, there is no noise from the pump and it is plugged in still! Haha!
i'll pop up the yard sometime in the next few days,
'58 C2 Code
xf1ref
x 11
Unread post by xf1ref »
Hi Timmo,
I have same problem like you, sometimes there is no noise from the pump. Yesterday I knocked the pump with a screwdrive handle and it works again.
I think the pump engine sometimes get stuck.
Timmo
(Donor 2022)
x 168
I do like the idea of hitting it! ;-)
Maybe try that After I have another! Hahahah!
'58 C2 Code
x 5614
Percussive Maintenance, always a reliable standby :twisted:
Timmo
(Donor 2022)
x 168
£2 from the breakers and all sorted! :-D
First few psa's I looked at has the pump missing already, pulled one out a 306, had DB code on the bottom of the barrel, slightly newer 306had DD Xsara had a Totally different one! Pulled mine out with suitable bucket under and has DC code on it lol! Plugged in and all working tickety Boo! ;-) thanks for the help chaps! Much appreciated!
'58 C2 Code
