Hi Guys I am new to these forums but have been reading and searching them for the last few weeks.
I have recently brought myself a new (to me) C5 estate 2.0hdi (90hp I think). This isn't my first C5 I had a 2.0hdi 110hp exclusive se with all the extras a few years back, needless to say I'm currently missing a few of those options.
I am looking at retrofitting cruise control which seems simple enough, just need to find someone close to me in Kent that would be kind enough to sort out the lexia side of things for me once I have sourced the parts (switch to go under the glovebox & the stalk).
My C5 is according to the V5C - LX trim and as such has a rubbish display which doesn't really tell me anything. So I was thinking about swapping over to the triple line display, however I'm unsure if the display is plug and play, or if i need to fit sensors/switches, or if lexia activation is required.
Also I have searched the forums and also google but nothing pops up for it, is it possible to retrofit electric windows in the rear? If so what is required?
Thanks in advance.
Fitting extras to a Mk1 C5 (2001)
c5gordy
Re: Fitting extras to a Mk1 C5 (2001)
Hi, I don't know about the electric rear window upgrade but I fitted the three line display and the speedo/rev counter pot from an SX to my 52 reg LX and they both worked straight away. Hope this is of some help . G.
waynedance
- x 8
pop out the window switch on drivers door and see what wiring is there. Rear window car will have extra connections surely like for the button to disable the rears.
Volvo S80 D5.........
citroenxm
- Fallen Hero
- x 70
Im useing an lx hdi auto and needed to fit a rear door lock and from what It seemed to me the wires were there for the window motor in the door.
early c5s in mark one DO NOT need the key code card to activate the cruise in the engine ecu. I fitted a cruise stalk to two mk.1s one my lx and a 2004 vtr for someone. Pop the stalk in then with lexia you change the config in the engine ecu only.. no need to access the bsi which is what needs the key code.
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
jgra1
- (Donor 2021)
- x 36
Hi jrc I don't think I am too far away and have lexia.. mine (sx) has cruise , auto dip mirror and leather from an exclusive .. you could also add parking sensors .. expect window wiring will be on car but as wayne says check.
What colour is car
John
What colour is car
John
Stempy
If you want the mirror there's one here
http://www.ebay.co.uk/itm/Citroen-C5-au ... 4ada6c0d6b" onclick="window.open(this.href);return false;
Lexia ponce
Lexia ponce
Bandit12
- x 12
Hi mate I'm in Northfleet and have a lexia. PM me your details like a mobile etc and we can arrange to meet up and I'll give you a hand
Bandit
Bandit
2002 Citroen C5 2.2Hdi exclusive estate (sadly gone)
2009 Citroën C5 X7 2.0 hdi (136bhp) exclusive estate (Oh wow what an upgrade)
