I've got a 02 Dispatch and the steering fluid tank isn't transparent anymore so it's impossible to check the level from the outside. After I pulled out the black filter from the center of the tank I noticed there is a notch at the bottom. I also noticed on the filter there are alignment marks at the top (180deg apart) but I couldn't see anything to line them up with. Which way should the filter be oriented?
