Undoing Lowered Suspension 206.
boltonbloke
Hello all. My girlfriend has just bought a 51 plate 206 2litre hdi. It seems that the previous owner was a boy racer and has lowered the suspension. This makes for an uncomfortable drive, especially going over a speed bump. I have been told that restoring the suspension to normal is an easy job requiring an easy adjustment. Is this true....or has she bought a lemon??? Replies appreciated. Thanks.
- x 1240
Re: Undoing Lowered Suspension 206.
I would think that the front shouldn't be to difficult, just replace the springs with standard ones, I don't know what type of rear suspension it has but if its torsion bar it might be possible to adjust it.
Oldpug
- x 94
As said above.........A lot depends on how much "boy racer kit" has been fitted?? The front struts and rear shocks could have been replaced for short travel stiff ones?? A Peugeot expert should be able to tell you if they are non standard parts.Replacing all this is a very simple job. All 206`s have torsion bar rear suspension,so the ride height can be adjusted.A straight forward job for a Peugeot expert.Especially if it has been done before, the torsion bar splines should be greased and not seized??
boltonbloke
Thanks guys.
