C5 4HP20
pavlebo
C5 4HP20
Unread post by pavlebo »
I have c5 with automatic gearbox 4HP20. Today we hear a strange sound from the direction of the gearbox. When placed gearbox in position D, the car goes for about 500m and then stopped, changed from D to R is not helping. I turned off the car and after 15 minutes, repeat, C5 go around 500m to 1 km, and then stop again. Pressing the accelerator pedal is not helping.
Whether the transmission is destroyed?
citroenxm
Fallen Hero
x 70
Re: C5 4HP20
Unread post by citroenxm »
Yes it sounds like the box has expired and will need replacment or rebuild.. Had it ever had a Fluid change at all?
What sort of miles,? Which engine petrol or diesel? Diesel 2.0 hdi use AL4 and 2.2 HDi use the HP4 20.
ZF claim a sealed for life gearbox, but none are really. A fluid change always helps a gearbox work for longer.
A very sad...
1994 XM 2.1 d auto
pavlebo
170000 km. Diesel 2.2 HDI. ZF 4hp20 gearbox. No, fluid never changed.
citroenxm
Fallen Hero
x 70
Re: C5 4HP20
Thats what has helped kill the box then sadly and its only going to be a replacement box or rebuild..
A very sad...
1994 XM 2.1 d auto
x 8391
Re: C5 4HP20
I concur it's dead.
Rebuild is possible but be prepared to replace the oil pump and have the TC refurbished.
See my website for details of how to do the rebuild. It's easier than it looks :wink:
x 1488
Re: C5 4HP20
CitroJim wrote: It's easier than it looks :wink:
We so need ROLF back :lol:
BTW, the page about splitting the box is not found, Jim....
Mandrake
x 695
Re: C5 4HP20
Unread post by Mandrake »
RichardW wrote: BTW, the page about splitting the box is not found, Jim....
The link in the top left works, the one in the bottom right doesn't...
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
x 8391
Re: C5 4HP20
Thanks both, I'll fix that when I'm next in the web server...
And I've brushed up on vi commands :wink:
x 8391
Re: C5 4HP20
:lol: :lol:
After just having done an RX-8 'box recently and having stripped an ML5 I still say automatic 'boxes are easier than any manual box...
Easier perhaps being a relative term :twisted:
citroenxm
Fallen Hero
x 70
Re: C5 4HP20
I need to delve into an al4 but need to work the courage to do it first. ..
A very sad...
1994 XM 2.1 d auto
x 8391
Re: C5 4HP20
citroenxm wrote:I need to delve into an al4 but need to work the courage to do it first. ..
Get a scrap one as a practice-piece and go for it Paul.
I never recommend going into one you want to fix properly unless you've practised first on a scrapper.
You've got the manual haven’t you?
citroenxm
Fallen Hero
x 70
Re: C5 4HP20
Yes I have.. anyone have a scrap al4 I can mess with then???
A very sad...
1994 XM 2.1 d auto
pavlebo
Re: C5 4HP20
I got another one, used, useable transmission 4 HP20, that has a similar mileage.
Tomorow i'll dismantle old one.
citroenxm
Fallen Hero
x 70
Re: C5 4HP20
DO A FLUID CHANGE NOW!!
Use ONLY Esso LT71141 fluid ONLY, DO NOT USE any Dexron type fluid!
A very sad...
1994 XM 2.1 d auto
x 8391
Re: C5 4HP20
citroenxm wrote:DO A FLUID CHANGE NOW!!
Paul, excellent advice on both counts :-D
The second is absolutely mandatory. Take care of fluids that claim to be LT71141 compatible. They aren't and a look at the small print will show they're actually Dexron III in disguise :evil:
Only Esso and Mobil make the genuine stuff.
