Citroen C5 AL4 stuck
nuwannow
Unread post by nuwannow »
Hey
im in trouble with my Citroen c5 AL4 gear box
with jerking some times and indicates gear box fault,its on lexia by fault code 06
x 3296
Re: Citroen C5 AL4 stuck
Well, welcome to the forum. If you hang on somebody you knows these gearboxes will pop up an answer or where to start looking.
Mandrake
x 695
Unread post by Mandrake »
If you've had it on a Lexia there must be more than just error code "06" - all Lexia errors have full text descriptions of stored faults. Can you post a screen shot including the extra freeze frame data recorded with the fault ? (Press enter on the fault code to get the extra detail)
Unfortunately I suspect fault code "06" won't mean anything to anyone, I certainly don't know what it means.
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
nuwannow
here attached video of some faults
usually comes with fault code 06
fault code 73 is not remaining
x 8411
The description of the fault is in red, a pressure regulation fault.
That'll likely be caused by the usual problem with these 'boxes. The pressure regulation electrovalves.
I believe they're replacable. I have no direct experience but either a search on here or a patient wait for one of our AL4 specialists to comment will confirm.
nuwannow
thanx jim
hope so someone help me... =D>
when fault come line pressure becomes 21bar,then it can reset by restarting of the car.... :lol:
nuwannow
anyone with any solution for this matter?
