Citroen Xantia Power Steering Pipe Repair Kit.
This is an ARCHIVE of common fixes. Material for this section should be submitted to an Admin or Moderator for approval then inclusion.
mardybum
Unread post by mardybum »
Up for your delectation today, we have a CUSTOM designed and made replacement for the Power Assisted Steering Hose on the Citroen Xantia.
I purchased the car, knowing it needed work. The previous owner had been quoted in the region of £500, 2 days, and that wasn't a guaranteed fix either. It took a few £££'s to get it right, and arguing with the hydraulics company I used, but in the end, I made the replacement myself, as I kept getting told that it wasn't possible.
This is guaranteed to fit as a direct replacement for the rusted and corroded one your car currently sports. I know this, as mine is doing so at the moment!
Supplied in the package will be;
1x SAE 100R2S-AT 2 Wire Reinforced Hydraulic Hose complete with Swivel fittings.
1x Custom machined M10x1mm fitting
1x Custom machined M12x1mm fitting
2x M10x1mm Long 3/16 Fitting
2x M12x1mm 3/16 Fitting
This neat little package will have your power steering and LHM leakage sorted in no time at all, being a direct replacement.
PLEASE NOTE
THESE ARE MADE TO ORDER IN HOUSE AND WILL TAKE APPROX. 1 DAY TO MANUFACTURE!
NO FITTING INSTRUCTION ARE SUPPLIED, HOWEVER, THE PROCESS IS STRAIGHT FORWARD!
NO KUNIFER/COPPER PIPE IS INCLUDED BUT CAN BE SUPPLIED AT EXTRA COST.
The price I hear you scream? Delivered to your door for £40!!
c.morewood
x 55
Re: Citroen Xantia Power Steering Pipe Repair Kit.
Unread post by c.morewood »
May I be the first of many Xantia owners to congratulate and thank you =D> =D> =D> =D> =D> =D> =D> =D> =D> =D> .. I'm sure you will have almost every Xantia owner on the forum making a huge sigh of relief knowing that their cars won't have to be scrapped due to a fairly simple pipe replacement.
My order (its worth it for the just in case factor) Will be in next month.
Jim may I suggest that this goes in the common problems and fixes?
Tesla Model 3 LR DM AWD Blue White
'00 Xant 110HdiSX Est 83K "W"
'99 Xant 110HdiSX Est 320K "V"
'98 Xant 1.9TDSX Est 150K "T"
'97 Xant 1.9TD 20k Est
'94 Fiat TipoTd 40K
'85 BMW K100RT 330K Garaged 26yrs '80 Honda CB250 twin Superdream
