Hi All
I have a problem with my 807 2.0 hdi overboosting and bringing up fault code P0238
The engine has the boost solenoid located at the front of the engine and I would like to check all the vac pipes to make sure everything is correct.
Has anyone got a diagram available?
Many Thanks
2007 2.0 HDi 136 Vac Pipe Diagram Needed
Re: 2007 2.0 HDi 136 Vac Pipe Diagram Needed
I done a scan for faults this evening using diagbox and I'm getting the codes below.
P0238
P2563
P0234
Regards
P0238
P2563
P0234
Regards
