Am intending to install a relay to shunt current past the vulnerable switching contacts in the ignition switch.
Having removed 2 "security head" screws from the bottom of the plastic shroud that encloses the ignition switch, I have found
the application of moderate manipulative force does not induce separation.
Are there extra catches, or a secret handshake ? Brute force ?
ACCESSING XANTIA IGNITION SWITCH
acrowot
This is from memory which is not very good these days,on my car (1996 SXTD) I removed the steering wheel (taking the necessary precautions with the air bag),remove the screws from the top shroud. the top shroud has now to be prised up on the right hand side, it has a sort of plastic clip going into the bottom shroud, when the top shroud is off you can see a further screw in the socket part of the clip, this screw has to be removed along with the other screws in the bottom shroud to allow removal of the bottom shroud.
MW
oilyspanner
acrowot
The removal of the airbag is fully described in the Haynes Manual, you need to disconnect the battery and the have a cup of tea,( just leave disconnected for at least 10mins before continuing, this deactivates the bag).You now need to turn the wheel to expose the holes on the back steering wheel boss, these holes are covered with a rubber membrane, through these holes you have access to the two securind screws, when these two bolts are unscrewed you can remove the bag (be careful at this point the ECU is connected to a ribbon cable and it needs to be unplugged, just ease out the bag until you can see this plug and disconnect it). When the bag is removed you will see another ribbon cable attached to the steering wheel radio controls, this has to be disconnected also. You now need to undo the nut in the center of the steering wheel that holds the wheel on(DO NOT FULLY REMOVE THIS NUT AT THIS POINT)you now need to free the steering wheel so that it will come off, this requires quite a bit of effort and if the nut is completely removed the wheel will come off with a jerk and can snap the two connectors from the ribbon cables(don't ask how I know).Once the wheel is loose remove the nut and carefully feed the ribbon cable through the wheel as you remove it. This job sounds complicated but in reality it is quite simple, the first time is always the worst (takes longer). If I had to do this job again I would estimate 5mins to do it plus the 10min.wait for the bag to deactivate.Don't forget you will need your Radio Code if you do this job. Good Luck.
Dave Burns
