Assistance with Service Citroen
KennyW
x 165
Unread post by KennyW »
Hi All,
Tried find the part no for the metal brake which holds the brake wear indicator wires and ABS cables on the front.
Can someone assist. it will be there somewhere but where ](*,) :-?
Kenny
PS
Chassis No VF7**************[VIN obfuscated, can be read by forum staff] if required
C3 1.4 petrol (SWMBO)
kenhall1202
Re: Assistance with Service Citroen
Unread post by kenhall1202 »
Pipe fastener clip 454842 ?? unfortunately shown as NFP
Ken Hall
KennyW
x 165
Thanks for the replies, part no's are 4547F3 and 4547F4 for left and right. $2.24 each.
Kenny
KennyW
x 165
Mike,
You're correct I got it wrong :oops:
Still trying to find same, I will post a picture of mine. I've had the Dremel out removing the rust and have now painted it black.
Just need to find 1 more to run the cables properly to stop further accidents.
Kenny
KennyW
x 165
Mike,
I think I have found them Part No's 96111429 left and 96 11430 right ($6.95 each) bolt 96 995 879.
Kenny
x 94
Unread post by citronut »
at least they are still showing as available from Citroen all be it at nearly £7 squid a piece #-o :wink:
Regards, malcolm.
KennyW
x 165
I think the only way to see if they are right is order them. I'm going to order one soon as my other one has come up well after the Dremel treatment and a respray.
Kenny
KennyW
x 165
Mike,
Here's a photo of bracket i took off my Xantia
Hope this helps.
Kenny
Old-Guy
x 26
Unread post by Old-Guy »
Commiserations! Over the last few years, I've spent many frustrating hours trying to find Xantia parts on service.citroen. In some cases there's no logic to the allocation of parts to particular section/subsections - sometimes you can see the part you're looikng for greyed-out in the obvious subsection, but it doesn't appear anywhere else in that section. The weird translations from French to English don't help - some have clearly been done by various different people with no knowledge of English or of automotive engineering. For example, what we would naturally call a hose (i.e. a largish diameter flexible pipe), is variously translated from the French as pipe, tube and sometimes even hose without any consistency at all. At times, it's like a Chinglish user manual - sense can be made of the translation if you know what it should be in English! Rant over!
