the video gives you a step by step tutorial how to replace the cylinder gasket of at your Peugeot with the 1.4l TU3 JP engine. A broken head gasket is a rather typical failure of this engine. Most times you'll find cooling liquid in the oil, oil in the cooling liquid, or the engine is loosing oil a the right front side:
The video has a German soundtrack but English subtitles are available at YouTube. If you don't see them by default, watch the video directly at YouTube and press the subtitle button below the frame.
Enjoy it,
Jürgen
Video: Replacing the cylinder head gasket
luby
Re: Video: Replacing the cylinder head gasket
Hi Jürgen, thanks heaps. I subscribed to your youtube channel a while back. I will be replacing the head gasket, a water pump and a cambelt in wife's 206 soon. I find your videos to be the most informative.
