Identify this sphere ...
x 94
Re: Identify this sphere ...
Unread post by citronut »
look like hydractive by the pipe port size
Regards, malcolm.
x 8386
Re:
superloopy wrote:What size is that then?
The size you see Mike. Non-Hydractive are very much smaller and are tapped M9.
Those you have are certainly Hydractive but could be V6 ones. The acid test is to measure the strut hole at the top.
xantos
x 10
Unread post by xantos »
You forget easily? [-X
http://www.frenchcarforum.co.uk/forum/v ... 0&start=75" onclick="window.open(this.href);return false;
V6.
Xantia Break 1.9TD (jammed b****!)
Xantia Activa 2.0 TCT + LPG (1998) (peeing b****!) RIP
Xantia Activa 2.0 TCT (1998) (burnt b****!)
Xantia Activa 3.0 V6 (1998) (not a b****! yet :-D )
C4 Exclusive 2.0 HDi (gear shifting b****!)
