Has anyone ever changed the electronic module/sensor fitted to the Lucas Epic pump and if so is there any setting up or programming of the new module after it being fitted. Hopefully it is a straight swap. Also if you have replaced the module what were the symptoms or reason you had to change it. My symptoms include an intermittent diesel knock, rough running and sometimes smokey. A Lexia session on my Xantia 2.1TD found that the diesel thermistor and cam sensors 1 and 2 were faulty. I suspect these sensors are contained within this module which is very expensive. I have attached photos of a similar sensor.
Thanks,
Brian
