Just a cautionary word to anyone fitting a Moog balljoint kit to a ZX with PAS - the 15mm hexhead bolts supplied with the kit can foul the swivel joint/balljoint clamp bolt, obstructing the steering action. The original Torx bolts have a much lower profile head so I had to re-use one of them instead.
In case you've not read my previous post - beware the drive shaft dissengaging from the gearbox with the ball joint removed...![}:)]
