Hi guys I have a 2005 citroen c5 design estate. Since january I have been having a funny tick coming from the front passenger side wheel. I have had the cv joints checked the suspension seems fine so I am stumped to know what it is. The ticking only happens if I am on hard lock right and at pulling away speed. Somwtines the tick doesnt even happen sometimes all the time any ideas guys? I thought maybe something wrong with the hub. My esp warning comes on every few thousand miles intermitently is this related perhaps? Any help is always appreciated.
C5 ticking
hamster99
Re: C5 ticking
I had a similar problem on drivers side although it was a severe knocking and happened all the time. Turns out it was the guide bracket for the handbrake cable on top of the hub had moved slightly and was then hitting one of the weights on the inside rim of my wheel. Pushed the bracket back a bit, job done and not happened since.
If it is also only happening on hard lock right then check the wheel arch liner, they can come a bit loose.
Rob
Rob
22 C4 1.6 eHDI Shine Plus
67 RR Autobiography 4.4 SDV8
15 C4 1.6 eHDI 115 Exclusive - fond memories
12 RR Westminster 4.4 TDV8 - Gentleman's Club on wheels
05 C5 2.0 HDI 138 Exclusive - gone but not forgotten
05 C5 2.0 HDI 138 VTR - crushed May 2015
