was driving and i lost powering steering managed to get home as not got far and it has slipped off?
Before this though there was like a trickleing noise come from that area?
Are these easy to replace?
Thank you
C5 estate alternator belt
ej2095
C5 2.2 HDI Estate mk1 (With a anti theft fury dice device)
- x 1240
Re: C5 estate alternator belt
Noise could have been the belt disintegrating but after fitting a new one have a good look at it running to make sure its sitting squarely on the pulleys. There is a tensioner that you need to release which can be a bit difficult unless you have three hands, a Haynes manual would be a good investment. Before you order a new belt check the old one for length or if its broken work out the length by wrapping a piece of sting round the route, they have a happy knack of sending the wrong size.
- x 94
you also have to be aware if/when the aux drive belt fails/shreads/comes off, there is a high possibility parts of the aux belt can worm there way into the cam belt covers, and cause the cam belt to fail,
it is a prudent measure after aux belt failure to remove all the cam belt covers just for peace of mind,
whilst your in there is a good time to fit a new cam belt as well, of course not if its recently been done, and theres no sign of aux belt in there
Regards, malcolm.
ej2095
Took belt off and it was fine had closer look at the cog on the alternator has moved to the left..
So after finaley removed int alternator the cog on it appears to be (-expletive removed-).
will order a new/old one off ebay
ej2095
All done took me 1.5 hours to complete
bare in mind i am a novice when it comes to fixing cars.
was good fun though
tested and cars is fine now and that trickleing noise has vanished..
was good fun though
- x 1240
All good experience. Well done
