Well I managed to load the Lexia (not Diagbox) onto a Windows 7 64bit laptop under XP Mode and after a bit of fiddling with the 30 pin socket I linked to the car.
Found 2 faults on the alarm
Re-supply relay - where is it?
Engine control unit connection - is this the one under the carpet (mine is now above the carpet)?
Found one fault with the injection
Intermittent fault fast idle solenoid valve short circuit to -ve or open circuit - do I need to get this fixed?
Any thoughts gratefully received,
Juliet
