2.0hdi 90hp Berlingo 2003 non dpf limp mode
Roadrally
Hi all
Hope someone might be able to help.
Got a 2003 2.0hdi 90hp Berlingo with the following faults.
pre post heating relay circuit coherence
Permanent fault inlet air temperature signal short circuit to + or open circuit
Had new maf and heater relay (and new glow plugs before I got it)
Pre post heater relay unit (on side of battery tray) had to be rewired.
Had to repair some of the loom wires from ecu that had started to corrode
Faults we're read both on Lexia and pp2000
Anyone else had similar?
Cheers in advance
Cheers in advance
- x 1240
Re: 2.0hdi 90hp Berlingo 2003 non dpf
What's it doing - or not doing?
Roadrally
Dropping into limp mode and staying there
- x 1240
Firstly have you changed the fuel filter? If so another cause of this is the filter in the pressure regulator on the HP pump becoming blocked, this is assuming it has a Bosch fuel system.
Roadrally
Live data is a showing excessive air flow, (450ish) should be 240, egr electrovalve shows 10% and should be between 55 and 80, also now putting out a little white/ blue/ black smoke when revved.
Yes it's had a filter, also drained fuel and replaced with v-power, maf,electrovalve etc
Egr has been off, that's ok and works when you suck the pipe.
Turbo vanes are good, no movement.
Fuel pressure within tolerance so doubt it's a filter in hp pump (is that the 1 in the tank?)
It's the Siemens 801 ecu"
Couldn't get the air pipes out from behind engine so couldn't clean them out.
Will check if timing is correcd
In limp mode all the time now unless left over night
Northern_Mike
Roadrally
That's a bonus, heard of a few in tank pump failures. I presumed that all hdi's had them.
- x 1047
Has the EGR valve been blanked off ? That would explain the high airflow reading at idle.Roadrally wrote:Live data is a showing excessive air flow, (450ish) should be 240
Northern_Mike
Roadrally
Egr not blanked, when I took the heat exchanger off the aluminium inlet was almost blocked with oily deposits from resurc.
Egr valve opens and closes sucking on pipe.
Can feel suction from vacuum pump but not sure if it's enough, the electrovalve reading at tick over is only 10% and should be between 55 and 80.
Will put oil flush through just incase there is a build up of gunk in rocker and lifters.
Roadrally
Re: 2.0hdi 90hp Berlingo 2003 non dpf limp mode
Ok, timing perfect, test on foot brake suggests vacuum is good.
Had a chat with cit pug dealer and suggested injection control module (brown 15 pin) which computer says it has but I cannot find at all, had all wiring out so it's not hiding anywhere.
Turbo wastegate is next port of call!
Roadrally
Seems to be something temperature related, as it will run ok for a little while, eml light comes on but if you switch the ignition off then it goes out only until the temperature gets up to about 50.
All parameters look good now!
I put a new temp sensor in as soon as I got the van unless it's a faulty one.
No faults logged but light is on permanently when warm?!
Anyone had anything similar?
- x 1047
I assume they mean the double injection relay ? If so a mk 2 berlingo doesent have one, its integrated into the under bonnet fusebox.Roadrally wrote: Had a chat with cit pug dealer and suggested injection control module (brown 15 pin) which computer says it has but I cannot find at all
Roadrally
I decided that it was part of the fusebox because I had all the wiring out around the front and couldn't find it.wheeler wrote:I assume they mean the double injection relay ? If so a mk 2 berlingo doesent have one, its integrated into the under bonnet fusebox.Roadrally wrote: Had a chat with cit pug dealer and suggested injection control module (brown 15 pin) which computer says it has but I cannot find at all
Don't believe everything the computer says!
Kone
- New User
Any idea what the solution was finally?
same problem here
same problem here
