clutch problems
darbuck
- x 291
clutch problems
hi lads ,looking for some advice I've been trying to sort out 2003 c5 2.o hdi 110 for nearly a month now swapped out engines now cant get clutch to work iIknow clutch is in right also replaced slave but pedal wont go down after its bled its not releasing hydraulicaly and i know its definitely hydraulic problem help!!!! '
Darren
flying clutchman
- x 3
Re: clutch problems
Pretty sure this model has a pull-type clutc. If the pedal won't push down it's because the bearing isn't clipped into the cover, or the arm isn't engaged on the bearing carrier
sparksie
- x 33
Re: clutch problems
Been wondering about this.
Any dander you've used the wrong clutch components?
If you used the clutch cover from the "new" engine, it may be that it's not the right one for the car!
Just a thought...
Just a thought...
Sparksie
2000 Xantia 1.9TurboD
darbuck
- x 291
Re: clutch problems
no just tick .had the bearing off the fork just need a labotomy installed actual clutch wrong thanks lads
Darren
sparksie
- x 33
Re: clutch problems
Nah.darbuck wrote:no just tick .had the bearing off the fork just need a labotomy installed actual clutch wrong thanks lads
Can happen to anyone.
All it takes is a moment's distraction.
Glad you figured it out.
Sparksie
