so in my stupidity I took the door card off and started messing with the motor, I took the motor off not realising how it attached to the regulator, and as usual I messed everything up when the cables came off the regulator and unravelled al over the place. Is there a video or a how-to n how to get these cables back on the regulator and not tear ones hair out in the process? Any help would be appreciated
306 window regulator
orinoco74
k its probably my own fault for messing, but if u don't try u don't learn, right? well the issue started when my window would only go down and not up on my 2000 reg 306 on the passengers side on either button (drivers side window switch or passenger side window switch). It would only go down not up.
Oldpug
- x 94
Re: 306 window regulator
Well,you have learned, the hard way. It started with a fault now its fell to bits and well f######! it will never work properly again,guaranteed.orinoco74 wrote:k its probably my own fault for messing, but if u don't try u don't learn, right?
GSF supply a window rack assembly with motor ready to fit for about £80.
