2002 307 2.0 HDI wont turn off with ignition key.
spender1
New User
Unread post by spender1 »
I have a 2002 307 Hdi but when you switch the ignition key off the engine continues to run, it will only stop when you press the brake pedal or open the glove box so the light comes on! I have done a code scan with Autocomn and I get p00cc code and an airflow at lower limit message with no error code.
Gibbo_Wirral
Re: 2002 307 2.0 HDI wont turn off with ignition key.
Unread post by Gibbo_Wirral »
You need to get a better diagnostic check done. Have a look on the Lexia owners thread and find someone local to you with the Lexia cable and Peugeot Planet or Diagbox diagnostic gear.
Peugeot Planet Diagnostics: Wirral, Merseyside, Lancashire, Cheshire, North Wales
x 1055
Unread post by wheeler »
Have you changed a rear bulb recently by any chance ? This can happen if you fit a single filament bulb when it's meant to be a twin filament.
spender1
New User
No I haven't but I was kinda suspecting an electrical problem so I did disconnect both rear light clusters and it was still the same, thanks for the advice.
