xantia exc 99 t reg hdi 110 turbo problems
jacksun1987
Don't know how or why it's happend we was shorting out the cooling fan sender unit. To see if the other fan worked the car cut out but started fine drove home noticed the reponse was low at 2k Reves ok as soon as it goes up to 3k reves it was sluggish was putting my foot hard down in every gear nothing I had that car on hot summers day 3rd gear foot down to 30 to 60 in no time there's also a orange light on dash boerd it's a 110 hdi t reg
jacksun1987
Re: xantia exc 99 t reg hdi 110 turbo problems
what could it be is it the turbo or somthing else if i put my car for sale who would want it i found this what looks tempting cheaper tax should be cheaper insuerance cos its a lower spec http://www.autotrader.co.uk/classified/ ... ?logcode=p" onclick="window.open(this.href);return false;
its in leeds anyone near there what could have a lok for us
phoned him up he says he will take my car for scrap value
thanks
thanks
jacksun1987
I phoned him up he said Leeds I'm sure he did
jacksun1987
If I did put mine up for sale it's got a brand new low presser fuel pump alloy wheels are in superb condition heated leather seats work got mot till March tax till end of Aug yes I know the cooling fans and the turbo are up the creek and the interia window mirror keeps falling off just did my head in sorted the doors painted them starting to look all right again then this
jacksun1987
you are right its ML MOTORS
105 CHAPEL STREET
LEIGH, WIGAN
WN7 2DA
says its a 100 miles away from where i am
105 CHAPEL STREET
LEIGH, WIGAN
WN7 2DA
Northern_Mike
Re: Re: xantia exc 99 t reg hdi 110 turbo problems
Probably not the turbo. They are very reliable on the HDI.jacksun1987 wrote:what could it be is it the turbo or somthing else
You've probably just confused the hell out the ECU or damaged something by shorting the sender. You need to get it on a Lexia to find out what. My guess is that it thinks it's too hot and gone into limp home mode because of the sensor fiddling you did.
You have to remember just about everything is linked to an ECU in these cars and fiddling and shorting stuff out isn't like it used to be on ancient cars - on these modern cars it can really bugger things up.
jacksun1987
if i took the ecu off plug it back in againe would that reset things or take the battery off and put it back in
jacksun1987
just started it up put my foot right doown it does not go past 2900 rpm
jacksun1987
the light what is on is a engine auto diagnosis one
jacksun1987
think its sorted it the battery off put it back on the revs are all k now got it 4500 rpm but the lights still on
c.morewood
- x 55
Try this Jacksun
PSA BSI reset procedure
Put the driver's window down, lift the bonnet and ensure all equipment is switched off.
Ensure all doors are closed and remove key from the ignition.
Wait for 3 minutes, disconnect the vehicle battery and wait 15 seconds.
Reconnect the vehicle battery, wait a further 10 seconds (do not open doors.).
Switch on the side lights through the driver's window.
Switch on the ignition and check system's functionality.
Hold lock button on key down for 10 seconds.
Remove key open & close door test central locking system.
Start the engine and complete the system's check.
Failure to follow this procedure could result in incorrect operation of many BSI related items.
Hope this helps
Hope this helps
Tesla Model 3 LR DM AWD Blue White
'00 Xant 110HdiSX Est 83K "W"
'99 Xant 110HdiSX Est 320K "V"
'98 Xant 1.9TDSX Est 150K "T"
'97 Xant 1.9TD 20k Est
'94 Fiat TipoTd 40K
'85 BMW K100RT 330K Garaged 26yrs '80 Honda CB250 twin Superdream
'94 Fiat TipoTd 40K
jacksun1987
we havnt got a button on key ill see how it drives tomo thanks for the info information. Ill see what happens. Like i say there's no cooling fans so it might be. Why the light is still on. I think it stay on for a second before then went off. But on all the time now
citroenxm
- Fallen Hero
- x 70
Dont bother. Xantias dont have a bsi unit so that wont help you..
limp mode will need a lexia to sort it out. No other way about it.
wastegates need a vaccuum to close else it stays open without one.. so no turbo boost.
Vaccuumm is delivered via one of the electro valves by the drivers sphere on the left.
if its dead try swapping with the other one but MAKE SURE YOU KEEP ALL PIPE CONNECTIONS THE SAME.
its a small issue. But while in limp mode you have no chance of testing the turbo boost.
daft to get rid for something smal.
my xantia is on 284k and has no turbo problems what so ever. These are theast of engines with good strong mechanicals.
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
jacksun1987
well it seems ok at moment after jusst disconnecting the battery ill take it out tomo see what happens
