Hydractive ECU - overvoltage suppressor
Old-Guy
x 24
Unread post by Old-Guy »
Sorting through the biuts salvaged from the VSX, I decided to separate the EPIC and Hydractive ECUs from their common mounting plate. Curious as to why the latter rattled, I opened it up: rattling around in the case was a Motorola MR2535S that has quite clearly got hot enough to flow the solder and fall off the PCB! :shock:
Yet another reason why the suspension never worked properly! :?
One item to come off the list of parts on offer, though if anyone wants it to play with they are welcome to it.
KP
x 27
Re: Hydractive ECU - overvoltage suppressor
Unread post by KP »
Maybe one Jim could save in his spare time if donated as I believe he has the bits to solder sensitive things :)
x 8391
KP wrote:Maybe one Jim could save in his spare time if donated as I believe he has the bits to solder sensitive things :)
Indeed :-D
Old-Guy
x 24
It's yours Jim if you want it, though I wonder what else may have suffered as a result. I refrained from tinkering further as the connectors are screwed to the case and I was being pressured to get the bits sorted, crated and stored out of the way!
