Hi guys,
Can some kind soul tell me the size of the sump plug to remove it, is it a box wrench or a torx fitting as it is looking rounded, it is a phase 2 56 plate .
Thanks,
Micky
C5 phase 2 sump plug size
micky707
Micky
Citroen C5 2.0 HDI VTR 138 48k
Citroen Xsara 1.6SX Brilliant car, 9 years and 119000 Miles
2 Pug 306's
Peugeot 207 1.4 Sport
Citroen ZX 1.9D
If it aint broke.......
2 Pug 306's
Citroen ZX 1.9D
dnsey
- x 19
Re: C5 phase 2 sump plug size
Mines a hex recess (Allen key) fitting, but I believe that some have a square recess.
They are very soft, and round off easily - I had to replace mine when I bought the car, but a chisel got a purchase on it with little trouble.
micky707
Cheers, it is an allen key recess but not sure what size it is.
Micky
2 Pug 306's
Citroen ZX 1.9D
2 Pug 306's
Citroen ZX 1.9D
micky707
Tried a chisel, but as you say its very soft and to no avail, any other ides welcome before i have to go to the guys at the workshop
Micky
2 Pug 306's
Citroen ZX 1.9D
2 Pug 306's
Citroen ZX 1.9D
JohnD
- x 72
The Mk 2 C5 which I've just parted with used an 8mm hex socket
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
hamster99
John's right, just checked mine and it's an 8mm hex.
If your's has started to round then you might need to insert a flat blade screwdriver on one of the faces to make it a tight fit.
Also, I would use an 8mm hex bit from a large socket set, not just a normal allen key, that way you have more precise control.
Once it's out, if it is damaged then get a replacement from Citroen (can't imagine it's that expensive)
Rob
Rob
22 C4 1.6 eHDI Shine Plus
67 RR Autobiography 4.4 SDV8
15 C4 1.6 eHDI 115 Exclusive - fond memories
12 RR Westminster 4.4 TDV8 - Gentleman's Club on wheels
05 C5 2.0 HDI 138 Exclusive - gone but not forgotten
05 C5 2.0 HDI 138 VTR - crushed May 2015
