manually pumping the rear up.. help
morto
im struggling to get my c5 in my garage to get the job done,, need to take the rear spheare off with the boot as there is fluid leaking from the boot and it wont rise but its so low its nearly banging on the floor to get into my garage,, any ideas i cud pump the rear up just for a minit or two so i can move the car
2002 2.2hdi C5
c.morewood
- x 55
Re: manually pumping the rear up.. help
Using levers is the only way I could raise my Xantia off the floor when fully depressurised,
A long bit of 2x4,CLS or larger and something under it to act as a fulcrum, close to the car.
Stick one end under the jacking point and put you weight on the other...now you need someone else to put a block under the sill and opposite sill.. keep on adding height to the fulcrum and the blocks on the opposite side.. you should be able to get enough height to get a trolley jack underneath.
Tesla Model 3 LR DM AWD Blue White
'00 Xant 110HdiSX Est 83K "W"
'99 Xant 110HdiSX Est 320K "V"
'98 Xant 1.9TDSX Est 150K "T"
'97 Xant 1.9TD 20k Est
'94 Fiat TipoTd 40K
'85 BMW K100RT 330K Garaged 26yrs '80 Honda CB250 twin Superdream
'94 Fiat TipoTd 40K
dnsey
- x 19
If it's outside at the moment, could you dig a hole deep enough to get a jack under it? I've done so more than once.
