1.4 Petrol Anti Pollution and Catalytic Converter Fault
Ketchup469
New User
Unread post by Ketchup469 »
Hi Guys,
Really hoping someone can help as I'm getting desperate! Bought my 307 about four months ago, an 03 plate with around 70k on the clock. The past few weeks I've been getting her juddering and struggling with power, the engine warning light coming on and anti-pollution fault flashing up. Managed to read an error code and it told us there was a fault in no4 injector. Tried swapping an injector out but could possibly have been the wrong one, also tried a new coil pack which had no effect. Since then the error has changed and its now saying catayltic converter fault, and the engine light wont stop flashing. The car has stalled on me a few times and if i dont keep the revs up then struggles to keep going.
I really can't afford to go to a main dealership near me, and I'm not sure I trust them anyway being as they managed to MOT the car and not notice a door wouldn't open!!! If anyone can help at all would be majorly appreciated, completely out of ideas :cry: :cry: :cry:
x 5672
Re: 1.4 Petrol Anti Pollution and Catalytic Converter Fault
First thing that occurs to me is that PSA engines have their cylinders numbered in the reverse of the conventional so if you swap what looks like injector #1 then you may be getting somewhere with it.
Ketchup469
New User
Thanks :) A friend of mine swapped the injector out so I will double check with him which one as I was at work at the time!!
addo
Sara Watson's Stalker
x 95
Unread post by addo »
What mileage?
Notwithstanding the injector message, can be worth checking the coils with either Peugeot Planet or Diagbox software, also you may simply have a blocked cat. There's probably a "test pipe" you can buy for substitution testing.
Gibbo_Wirral
Unread post by Gibbo_Wirral »
Check the Lexia map thread and find a local member to give you a Planet diagnostic.
Peugeot Planet Diagnostics: Wirral, Merseyside, Lancashire, Cheshire, North Wales
