Flashing hazards after ignition switched off
Jazzer
Unread post by Jazzer »
06 C5 , when i turn the ignition off , the hazards come one for just under a minute then go off by themselves.What have i touched? And which University should i apply to for the best course in Understanding the bloody thing.
Trainman
(Donor 2018)
x 43
Re: Flashing hazards after ignition switched off
Unread post by Trainman »
Are you locking the car with the key? I think the alarm is arming as this is usually what happens when the alarm is activated
Steve
http://c6owners.org/index.php
Jazzer
I am locking it with the key.I have been unable to lock it and and unlock it with the central locking.I thought i was getting round a problem, seems i am causing it.Can the central locking be re set? The battery has not been disconnected , but i have had some of the fuses out.
Many thanks for the reply
Pat
Trainman
(Donor 2018)
x 43
EXECELLENT!! That's that solved....
Next, disconnect battery, and leave disconnected for at least 2 hours , this will allow the bis to reconfigure when you reconnect the battery.
Once the time has elapsed, reconnect the battery and use the key fob to secure the car and I hen unlock it again (if you have a second fob, then use this to reopen the car).
So basically:
Battery off
Wait 2 hours
Battery on
Key fob 1 lock car
Key fob 2 unlock car
Steve
