Thinking about an 02 c5 2.2hdi auto....good or bad
stu9
- x 8
Anyone got or had one....I had 2.0 hdi manual, but read that the 2.2s are quite especially mpg is this right
SaabC5
Re: Thinking about an 02 c5 2.2hdi auto....good or bad
If you're looking for economy don't do it. My manual 2.2 will return 28-30mpg around town and 42-48mpg on a run. I have had it as high as 60mpg by hyper mileing and driving like a vicar. Knock about 4-6 mpg off for the auto
09 C5 X7 2.0Hdi Exclusive in Perla Nera black (the best colour)
- x 8286
These have the ZF 4HP20 autobox and these have a finite life and are basically a time-bomb that starts ticking at around 140K or sooner depending on how it's been used... Most have died by 170K.
It's not terminal and can be fixed with a gearbox overhaul. Something to bear in mind and bargain against.
An FSH showing regular gearbox ATF changes with the right stuff helps the box live a little longer.
stu9
- x 8
Stay away basically
citroenxm
- Fallen Hero
- x 70
Thats about right..
for ultimate long life the 2.0 8v which you have had IS the one to go for!!! And they do them in auto aswell..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
stu9
- x 8
Northern_Mike
When was the last 2.0 8V C5 made? Must be at least 10 years old by now.
Northern_Mike
I'm not so sure. Probably from the auto, yes, but I'm of the opinion that any 2.2 MK1 that's made it to this age without being scrapped probably works perfectly well, if a little thirsty.stu9 wrote:Stay away basically
citroenxm
- Fallen Hero
- x 70
The 8v 2.0 hdi lived untill the c5s first face lift which was 2005.. ish..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
SwissSPEC
Any reason why you wanted a 2.2? I'm guessing the extra power, why not get a 2.0hdi 8valve & get it re-mapped with as stage 1 as per the link http://www.hdi-tuning.co.uk/ecu-remappi ... DI110.html" onclick="window.open(this.href);return false; The best of both worlds, that extra performance when required, & if you drive it gently, then mpg should be better than standard. I'm seriously considering getting this done, once i've sorted out some other bits & bobs on my 2litre hdi estate.
CX GTI 2 Turbo (LHD) - Sorn
Bx Gti 16v
BX TZD Turbo - Sorn
C5 Mk1 LX 2.0HDi Estate
Mini Cooper D Clubman
Bx Gti 16v
BX TZD Turbo - Sorn
KP
- x 27
I think you'd need to be wary that some 2004 cars could be 2005MY but looking at the engine bay is the easiest bet as it will say HDi16 on them
