2.2HDi starter motor TORX bolts ?
aramsay
Unread post by aramsay »
Hello.
I am currently on holiday in France with my '02 C5 2.2HDi and the starter moter is playing up, and I want to replace it.
I did not, however, bring any TORX tools/bits with me....
Can someone confirm what T-?? TORX bit fits the x3 mounting bolts please, so I can buy one locally.
While I'm here....priced a unit via Norauto website @ Euro-150.....sound OK ? Any other Halfords type places I should try ?
Thanks.
waynedance
x 8
Unread post by waynedance »
Could you not find a garage to replace it, should not cost too much. No need to waste money on tools and keep hands clean and enjoy the holiday.
Volvo S80 D5.........
aramsay
Re:
waynedance wrote:Could you not find a garage to replace it, should not cost too much. No need to waste money on tools and keep hands clean and enjoy the holiday.
I've been quoted Euro-350 for a new starter or E-250 for a recon one ! PLus the 200+ for labour, it would blow our holiday budget !
I work in a garage, so the job is no bother. I can get a starter for E-150 from Norauto, so just now need a TORX bit.........
So....can someone please help ?
waynedance
x 8
Its been about 2 years since I did mine can not remember what the size was.
miked
x 6
Re: 2.2HDi starter motor TORX bolts ?
Unread post by miked »
Are you sure it's a torx? The bolts on my '03 2.0 HDi starter were 8mm hex (Allen key)
x 1480
service.citoen shows the same bolts for all C5s (except V6). They certainly look like allen heads on the drawing, but there's plenty of artistic licence on there :lol:
x 2941
miked wrote:Are you sure it's a torx? The bolts on my '03 2.0 HDi starter were 8mm hex (Allen key)
You are correct, they're Allen screws, not Torx.
cachaciero
x 9
Unread post by cachaciero »
Apropos starter motor generally.
Had mine fail a month or so back (125k miles), brushes had pretty well disintegrated, two had actually disappered and what was left of the spring was acting as the brush. One would have thought there would have been some indication prior to the day it stopped but no.
First thought was a replacement, however after a bit of research discovered that the majority of units on offer were foreign clones, worse they were only rated at 1.7Kw the 2.2 Bosch unit is 2.3 Kw unit. In the end repaired the one I had.
Complete Brush assembly was about £25.00, had to arrange a clamp device to clamp the field connection to the brush plate as spot welding as per original not an option. Cut the connection out of the original brush holder with generous side wings thus allowing the fitting of two 4mm bolts to clamp the connection to the new plate.
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
And the size of the allen bolt head im sure is an 8mm allen key...
A very sad...
1994 XM 2.1 d auto
cachaciero
x 9
citroenxm wrote:And the size of the allen bolt head im sure is an 8mm allen key...
Ah! forgot the answer to the question{ -) yes 8mm allan key and for one of them, the rear one as I remember it needs to be a short key, I had to cut one down to get in the space available.
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
aramsay
Thanks all.
I couldn't see the bolt head, so just assumed it was a Torx. Nice of Mr.Citroen to have a nice easy Allen head....
While I'm here..itwould appear the solenoid part of the starter has become damp from oil or diesel dripping from above somewhere, causing mechanism to "stick". Something else tocheck when home......
KP
x 27
Unread post by KP »
My dads recently done these and I'm sure he said it was an 8mm Allan bolt head.
They are the same across the hdi range though so a motor from a 2.0hdi will fit and I be my you could even source one on eBay uk with postage cheaper than that as when I looked they were around £60 or so...
cachaciero
x 9
KP wrote:My dads recently done these and I'm sure he said it was an 8mm Allan bolt head.
Yes you could fit a 2.0 ltr starter and probably a 1.6 as well but though they fit they ain't the same. The 2.2 starter motor is rated at 2.3 Kw and the 2.0 ltr @ 1.7 Kw some what less powefull. Would a 1.7Kw starter work in a 2.2? probably, though on a cold day with a battery that was down it might struggle a bit.
The £60.00 quid ones available of of E-bay and various parts vendors are generally rated at £1.7 kw and given their pedigree I would take that with a pinch of salt, you can find 2.3 Kw ones but they are more expensive. I did look for a recond Bosch starter and as I remember the price for such a beast was in the region of £120.00. Somebody in the trade explained it this way " we can sell a no name clone for a reasonable markup and get in return a genuine bosch unit which we can refurbish, generally for not a lot of money and sell back to the public as a genuine Bosch unit with a very lucrative markup. it's win win for us"
The Bosch is a quality bit of kit, some of the stories I read indicate that many of the cheap imports are not manufactured to anything like the same quality, it was for this reason that I decided to overhaul rather than replace.
I would advise anybody that has a 2.2 that has done 100K miles plus on the original starter to include replacing the starter motor brushes the next time they are considering doing some routine maintenance.
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
citroenxm
Fallen Hero
x 70
Just a point.. 1.6 hdi starters won't fit as they are on the Back of the engine... but all 2.0, 2.2 and 2.0 16v hdis are on the front as they are all dw family engines and 1.6 is a dv engine..
A very sad...
1994 XM 2.1 d auto
KP
x 27
Unread post by KP »
Well i never realised an they both crank over just as nicely, even when the 2.2 was sat for a week and started in the dead cold before first light recently :)
