Tracking
froggy
(Donor 2026)
x 4
Tracking
Unread post by froggy »
The F.N.S. tyre on my S1, is wearing on the inside ! The other tyres are ok.......the front tyres were fitted balanced and tracked December last year . is it possible the tracking is out on one tyre ? or could it be something else ? cheers Terry. :?:
Terry
Xantia TD lx series1 SORN
Peugeot 306 meridian [ the boss]
Xantia HDI Forte 1997 CC
Mandrake
x 695
Re: Tracking
Unread post by Mandrake »
Could be tracking - if there is too much toe out (a lot too much - normal is 0 to 3mm toe-out from memory) then one tyre will tend to take control and steer the car while the other tyre scrubs on the inside edge.
However before adjusting the tracking you would want to be sure that the tie rod joints are not worn out and that the lower arm bushes aren't worn out - if either of those are worn badly the effective wheel tracking will be constantly changing under dynamic conditions of cornering, braking, acceleration etc, and no adjustment of the tracking will fix it.
So check the condition of those first and then get the tracking checked/adjusted.
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
x 1240
Re: Tracking
Unread post by Peter.N. »
It could be that the wheel is not vertical, stand it on a level surface and check each wheel with a spirit level, they will lean in at the bottom slightly, that is the camber angle but they should both be about the same, if the n/s one is leaning the other way, worn bushes as Simon says.
You can't have one wheel out of track as the setting is the difference between the two wheels but the n/s tyre usually wears out faster then the o/s. Check the tread depth on the o/s wheel, you may well find that is also worn on the inside edge but not enough to be immediately obvious, if it is the toe in is to great.
froggy
(Donor 2026)
x 4
Re: Tracking
cheers
Terry
Mandrake
x 695
Re: Tracking
I'd have to look up the specs again to be sure Peter, but from memory there shouldn't be any camber on the front wheels of a Xantia - eg 0 degrees. It's normal for there to be a slight amount of negative camber on the rear wheels though.
Simon
1978 CX 2400
x 1240
Re: Tracking
Ah, I didn't know that but at least comparing both sides should give a clue. Never had occasion to investigate the rear wheels on the XM.
