Been Given A Xantia Estate HDI
harryjoe
Unread post by harryjoe »
Hi Guys.
I'm back again on the french scene after a few yrs away since having the XM and a 405 a few months back.
I have now been given a 2000 Xantia HDI Estate (Pics will follow) very nice it is too, but it has recently had new disc's and pads, but now the abs seems to cut in at low speed ie ; below 30 mph! when the ABS light is lit up on the dash the brakes work perfectly.
Now my answer is that - after having new pads etc does the system need bleeding? inc the ABS or does it sound like the ABS pump or module is naff
Any ideas ??
Nigel
1998 Xantia 1.8i 16v Auto (sold)
1997 Xantia 1.9 TD Estate (Resting with 231k) zzzzzz
1989 BX 19 RD (In a barn awaiting TLC)
2002 C5 2.2 HDI Auto Estate (Sold)
1994 XM 2.0 Turbo (Sold)
1983 Bertone X1/9 VS
1995 405 1.8 GLX Estate (sold)
2000 Xantia Estate 2l HDI 110K
x 3297
Re: Been Given A Xantia Estate HDI
You lucky b****r.
I would bleed the brakes each time any major work was done on them.
I would check the reluctor rings on the front drive shafts. If they crack (they do, when rust builds up on the drive shaft) they can spin at different speeds, which confuses the ABS to the point it takes itself off line (which then puts the ABS light on). Gracies' ABS played up when the rings has cracked, but the ABS got confused at motorway speeds.
There is a SERIOUS downside to the problem YOU have. While the ABS is sussing things out (takes a few seconds) the brakes don't work (well, the handbrake does). If this happens when you need to stop in a hurry you are not going to like it! There is a temporary way to prevent this happening, but it is one that is frowned upon; remove the fuse for the ABS. The reason people don't like suggesting it is that if you have an accident that the ABS might have prevented then court actions may happen. Personably I feel that unreliable ABS is more dangerous than disabled ABS.
What happens with your ABS system?
Northern_Mike
Sounds like the reluctor rings on the driveshaft are either filthy or broken. This tricks the ABS into activating. It's a most disconcerting feeling. My HDI did this, a friend I lent it to didn't expect it and ran into the back of someone. Someone he was following from an arranged meeting point to buy their car off them. In my car. My car I'd already sold to CitroJim....
It's therefore advisable to get it fixed :-)
Enviado desde mi GT-I9505 usando Tapatalk
harryjoe
Thanks for the replies Guys.
I will check the rings tomorrow, yes when applying the brakes when the light is not on it feels as if its not going to stop !!!
I will take pics tomorrow for the car.
A work mate who has had it for 11 yrs wanted a new car and said to me find me a new car with low mileage, she said the Xantia is mine, 110k and in lovley condition.
I have now given my Saab 9-5 est the the misses I just love the Xantia.
kEEP YOU ALL INFORMED
harryjoe
Leading on a little from the original thread !!.
Can anyone tell me what other Citroen alloy wheels will fit the Xantia, I don'y have a clue about offset etc
Just wanted to know if any from say a C4 would fit ???
x 3297
Try getting hold of Paul (citroenxm). He may have alloys for a Xantia, and he should know the specs.
harryjoe
Hahhh Yes
I forgot about Paul - Met him at Little Horwood meet Yr or Two ago, I think I still have his number.
He gave me a hell raising ride in his old XM s1 v6 he had at the time, I shall never forget that experience !
x 94
Unread post by citronut »
AAAAH Nigel how the hell are you bud
theres no need/reason for the brakes to require bleeding after fitting discs and pads, as usually the fluid side of the system has not been not been opened,
i agree with the reluctor rings either being cracked or clogged up with dirt, grease or rusty
Regards, malcolm.
lexi
x 134
Unread post by lexi »
As far as court actions go on ABS fuse removal?.........easy, just blow the fuse, then put it back in till you get fixed.
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Mandrake
x 694
Unread post by Mandrake »
lexi wrote:As far as court actions go on ABS fuse removal?.........easy, just blow the fuse, then put it back in till you get fixed.
It's hard to argue with the fiendish cleverness of your suggestion lexi... :twisted:
Having also experienced intermittent loss of brakes due to faulty ABS that nearly caused me to run into someone in front of me at low speed, I too would disable the ABS as a stop gap measure until the problem was sorted. And drive a bit more conservatively!
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
x 3297
Now THAT is a good way around that problem, but we had better stop 'talking' about it before somebody cottons on!
Northern_Mike
Can anyone point me to a single instance of a court case for something like this?
x 3297
Probably not, but in this age of litigation (bl00dy Yanks), why take the chance?
Northern_Mike
It would be difficult to prove liability, that's for sure.
neil123
Unread post by neil123 »
Lucky bloke!
I guess that sets a new benchmark low for HDi estate values -ie 'Pleased to be given it'
Can't be long now before they reach 'I'd be annoyed if i found one'!
Still, those of us who appreciate such things will continue not to care... I've just spent several hundred quid having every hydraulic pipe replaced after two annoying pipe bursts.. just because I didn't want to scrap a good car I've owned from new for want of a few pipes! I still use it most days in preference to my Discovery 3!
Its an addiction, really, this Xantia thing!
