Hi
I have a 53 Reg, 206cc, 2.0, 40k miles. The car feels to judder on cold start, no fluctuation on the tacho but the gearshift shakes etc. After a mile the 'anti pollution' message appears along with the EML. The only codes showing on 'planet' are 'permanent misfire cylinder 2 (p0302)' and 'intermittent misfire cylinder 2 (p1338)'
I have changed the plugs (Bosch) and the coil pack but no change. The car ides smoothly when warm?
Any help appreciated, heard stories about tappet issues ?
206cc misfire cylinder 2
- x 94
Re: 206cc misfire cylinder 2
my first thought on this would be coil pack, presuming it is a petrol car that is
Regards, malcolm.
johntom
Yes it's petrol. Plugs and coil pack changed no improvement
addo
- Sara Watson's Stalker
- x 95
johntom
Hi
The old plugs were all the same light brown colour, the gaps are ok. I have changed the plug and the coil pack so u suspect it's either the injector or the tappets ?
addo
- x 95
johntom
Hi the coil pack was new and made no difference. When the car is started from cold it idles smoothly for about 20 seconds then starts to judder, however it's ok from warm. The other day I sat holding the throttle at about 1500rpm from cold (to smooth it out), with a bit of revving the 'catalytic conveyor fault' message appeared with a flashing EML, then it changed to 'anti pollution fault' and a solid EML. Pretty sure that the light goes out when the car is near temperature so it must be heat related, expansion etc?
From the previous reply; I haven't compression tested it, I think planet gives fault codes for each individual cylinder?
- x 1055
you could try swapping number 2 injector with another cylinder & see if the fault moves, remember thought that PSA engines number the cylinders back to front & number 1 is at the flywheel end.
johntom
Hi
I have swapped 2 & 3 injectors this morning (as I wasn't sure about the Cylinder numbering, so I covered it either way). I started it and it still juddered but couldn't get it to bring on the EML and a code - probably because I let it idle too Long before setting off. The anti pollution etc comes on when it sets off from cold and revs for some reason. I will let it cool off and try again for a fault code.
addo
- x 95
johntom
Thanks where is the air pump and how do I check it?
Also why 'misfire cinder 2' ?
johntom
Hi
I have started and driven the car but can't get the EML to come although the car still judders as before when cold?
addo
- x 95
johntom
Still juddering on cold start up and no EML but it did pass it's MOT inc emission test.
