Got to change the COM2000 on my Sister's Xsara this weeknd. Unsure if the airbag is held on with bolts or clips. Service.citroen shows bolts (off VIN), but there are plenty on e-bay with clips, and I found a youtube vid that showed clips on a similar age car.... I'd rather bolts of course, as I gather getting the clips off is a bit hit an miss till you know / can see what you are doing, which of course you can't till you've got the clips free, and the air bag off
02 Xsara - Driver's air bag, bolts or clips?
- x 1496
Place your bets....
Northern_Mike
Mandrake
- x 695
Re: 02 Xsara - Driver's air bag, bolts or clips?
That's a busy weekend you have planned Richard, COM2000 replacement, strut bearing replacement on the C4 - what are you doing for your third act ?
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
1978 CX 2400
Northern_Mike
- x 1496
I think it'll be a bit longer than 10 mins - but hopefully not too hard!
Remarkably, the spray grease I aimed in the general direction of the strut bearings last weekend has worked it way in, and stopped it graunching. Still going to change them though - otherwise no doubt will have a spring failure next week.
3rd act? Oil change on the Xsara, plus checking it over for MOT. Wonder if it might need the rear brakes stripping and cleaning....
PS If you're bored tomorrow, Simon.....
Mandrake
- x 695
Believe it or not I've got a day out and about with SWMBO planned tomorrow or I would. Its not just cars that require maintenance apparently.
If you get stuck on anything and are still going on Sunday let me know and I should be about.
Simon
1978 CX 2400
1978 CX 2400
- x 1496
Mandrake wrote:Its not just cars that require maintenance apparently.![]()
- x 1056
Yep, models with com2000 have clips, models without com2000 have T-30 screws.
On xsaras the clips push in towards the centre of the wheel, on C5's they push away from the centre.
- x 1496
Job done, clips it was - took me a good while to manage to release the bottom one. Air bag light now stays off
Act 3 was to change the oil in the Xsara, then followed by fixing a leak in the exhaust with a baked beans tin and jubilee clips
It needs a new CV gaiter clip, and not sure the handbrake will be good enough - not sure what's up with it, but I suspect it needs new cables really.
