Spring compressor recommendation
- x 1487
Anyone recommend good spring compressors? Looks like the C4 needs both front strut top bearings doing - SWMBO said it was graunching on lock, so as I had it jacked up today for the cambelt job, worked the steering back and fore, and both strut tops are juddering
Think it's on original springs (73k miles) so would put new springs in while it was apart as well. But no spring compressors at the mo, so would need to get some.... Looks like a bit of a fag on the C4 as the wipers / plastic scuttle etc will need to come off to get at the strut top mount. Surprisingly the bearing from Citroen is only £13 - cheaper than many after market seem to be - mind you, Cit want £95 for the springs. Each
Northern_Mike
addo
- Sara Watson's Stalker
- x 95
- x 94
Re: Spring compressor recommendation
i had to fit new front springs to a V*O*L*V*O V70 a year or two ago, which i thought i might need extra long spring compressors for,
so i purchased a set like these
http://tinyurl.com/luw9bya" onclick="window.open(this.href);return false;
Regards, malcolm.
- x 1487
Seen some double claw ones on the bay with 370mm reach for £12 (!) so probably go with them. Looks like half the car has to come apart to get to the top mount:
At least the drop links are relatively new, so will come out without too much trouble....
Perhaps this is the excuse I need to buy one of these: 'windy' gun
SWMBO currently pleased as it's running much better with the new cambelt fitted
Mandrake
- x 695
That's a relief that she's pleased Richard !RichardW wrote:SWMBO currently pleased as it's running much better with the new cambelt fitted
I'm quite surprised just how much difference the new belt made to the performance. The research on valve timing I did for my car had suggested that just a few degrees of retard of the camshafts could have quite a detrimental effect on low rpm torque, at least on a petrol engine - looks like the same is true of a diesel!
Rule of thumb I've seen is that an old stretched belt can cause a loss of as much as 4 degrees or so of timing, judging by the change in tilt in the crankshaft peg we saw before and after I would say we were easily seeing that much...
You can really see the benefit of vernier cams for getting the timing spot on, especially if you re-adjust them after the belt has had time to bed in! Non vernier cams where you can only set it to the nearest tooth are always going to be at the mercy of belt stretch variations...
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
1978 CX 2400
KP
- x 27
If your doing the springs and tops just save yourself a job and do the dampers.
You can always list the old ones on eBay and get a few quid back but why bother messing about with used but just put a nice new lot on and enjoy a good ride up front as at 73k if the springs and top mounts are showing wear the dampers can't be far behind and you know what will happen if you don't in a few months time....
- x 94
i have recently experienced this as i said in another thread SimonMandrake wrote:
"window cleaner customer of mine bought a petrol Pox all Ashtray the seller had just had the cam belt fitted,
on bringing the car to me saying it had absolutely no get up and go and was drinking the go go juice like it was going out of fashion,
first thing i checked was the cam timing only to find the pointer way off of were it should have bin,
i re/did the tension which sorted the running and fuel economy,"
Regards, malcolm.
- x 1487
An interesting thought Will - are you suggesting buying a strut complete, so it's just a mechanical change over? Do you know of a supplier - I had a quick search but nothing obvious showed up?
- x 1487
I had a look - Monroe do supply complete units (quick struts) but not for C4 Picasso yet. But on re-reading, perhaps you are suggesting just sticking in a new damper at the same time to avoid having to have it all out again in a few 000 miles time when it starts leaking.....
looks like 100 notes a side though, so think it can wait....
KP
- x 27
Yeah thats the idea or asking monroe to make the setup for you
IMO the cost isnt as bad as thinking about the waster time having to go back again...
You could just get the bits and then find a friend or local garage who could fit the springs in for you for a few quid...
- x 1487
Job done today. I had sprayed some grease in the direction of the bearing last week, which had improved things, but decided I would bash on anyway as I had the bits. Just as well I did, given this was the state of the OS one:
NS one was slightly better - it held together initially, but fell apart when touched! Needed a lot of winding on the compressors to get enough to get the top nut off, but for £12 they worked admirably
Had to take the wiper motors out so i could get an allen key in the top of the strut to free the retaining nut (on these the strut it held into the car with a second nut on the top of the strut rather than 3 nuts around the strut). Managed not to lose the gearbox oil as well
- x 94
good job Richard
those springy compressors are like the ones i bought,
that spring looks a bit more done one side than the other
Regards, malcolm.
Mandrake
- x 695
Job well done Richard.
Are those not sealed bearings or did they just fall in half during removal ?? Surely a bearing in such a hostile water and salt laden area would be a fully sealed type ?
Simon
1978 CX 2400
1978 CX 2400
- x 1487
Because the spring narrows at the bottom, and the lower plate is very wide, it's difficult to get the compressors on equally, but they did the job. Got it a bit more even on the second side!
The bearing is not supposed to come apart, but it's not really sealed. I was surprised at how bad it was really, but then it only cost £12 (even for an SNR one) so they're not exactly expensively made!
