Would I be able to feel a huge difference with Comfort spheres fitted, theres a company online http://www.sphere-shop.fr/" onclick="window.open(this.href);return false; (IFHS spheres) selling 4 for just under £100 non Hydractive. Should I just stick with the standard spheres?
Thanks..
Comfort Spheres
xantiagreen
Comfort Spheres
Faz
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
96 Xantia 2lt 16v Sx Olive green
01 Xantia 110 Hdi
Storm Grey (SOLD 4/11/18)
Temporarily driving Polo 1.9sdi
All I want is a Bx Gti or 16v!
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
01 Xantia 110 Hdi
- x 1240
Re: Comfort Spheres
They are probably cheap enough to buy as a spare set! Yes, you will notice a difference but only where the ride is at its best anyway, at reasonable speed on major roads, then its even better they don't make a great deal of difference for where hydropnumatic is at its weakest, low speeds on rough roads.
I tried an experiment once using accumulator spheres on the suspension, the ride really was superb with not a bump felt, unfortunately they don't handle well like that.
To answer your question, yes, I always used comfort spheres on my XMs because I like a really soft ride, but not everyone does, if that's what you like go ahead and fit them.
xantiagreen
Re: Comfort Spheres
Peter.N. wrote:They are probably cheap enough to buy as a spare set! Yes, you will notice a difference but only where the ride is at its best anyway, at reasonable speed on major roads, then its even better they don't make a great deal of difference for where hydropnumatic is at its weakest, low speeds on rough roads.
Cheers for info Peter, Will the spheres lose significant pressure if sat on shelf for 2 years (had full set od standard spheres fitted last year)
Faz
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
01 Xantia 110 Hdi
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
01 Xantia 110 Hdi
- x 1240
Re: Comfort Spheres
I have never experienced significant pressure loss with stored spheres, they obviously will go down slowly but not nearly as fast as when they are having their pressure drastically increased under working conditions.
