citroen c3 heating
danny1802
citroen c3 heating
Unread post by danny1802 »
hy there guy's....ive a problem whit me citroen c3 heating.....lately there no hot air coming out....only cold air even do its set on hot.....i checked the fuse's and there ok and same whit the heater resistor...so... anyone got any ideas?
sparksie
x 33
Re: citroen c3 heating
Unread post by sparksie »
danny1802 wrote:hy there guy's....ive a problem whit me citroen c3 heating.....lately there no hot air coming out....only cold air even do its set on hot.....i checked the fuse's and there ok and same whit the heater resistor...so... anyone got any ideas?
Check and top up the coolant?
Sparksie
2000 Xantia 1.9TurboD
x 94
Unread post by citronut »
hi and welcome
has the cooling system been drained/or run low on coolant???? prier to lack of hot from the heater,
does the heater fan run at all?????
Regards, malcolm.
danny1802
it is coolant in it....the fan runs but instead of hot air its cold....do drive more then 30 min and still cold air coming out
x 94
what year and engine is it????? and has it air con
first thing i would do is feel both the heater hoses under the bonnet at the bulkhead once the engine is up to temperature,
anther possibility is your flap servo/motor/cogs have sheared/striped, this can stop the hot cold flap operating,
Regards, malcolm.
danny1802
its an 1.1 engine 2006yr whit no aircon...i will have a look on what you said...thanks
danny1802
hy guys...just done a diagnostic and comes up this code p0598 thermostat heater control circuit low...any ideeas wat it is?
Martiano 1
New User
Unread post by Martiano 1 »
I have same with 07 desire 1.4, I did run out of coolant filled with water was running ok but recently gone cold garage flushed and topped with anti freeze but still cold. If I pump hoses warm air comes through but not for long.. garage suggested water pump?
x 6950
Did you not have the water pump replaced when it had the timing belt done? This is usually done at the same time along with the pulleys given the labour costs of replacing the water pump alone at a later date. The pump is a likely candidate if you can circulate the water manually.
