megan injection fault ?
vewee
- New User
Hi i have a 2004 1.5dci it wont crank over only showing injection fault on dash display . Ive check connections between uch and ecu also all fuses and earth points , also borrowed a spare uch but still the same .Only codes are main relay df015 HELP!
Lighty
- x 34
Re: megan injection fault ?
Usually the underbonnet fuse board, I suggest you get a replacement and try that. Also check the main power leads around the battery itself, they rot completely through sometimes.
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
Citroen C15
Citroen Ami
steelcityuk
Renaults are notorious for loom corrosion around the battery tray, it's usually only discovered after the car won't start and requires careful examination of the loom, the corrosion can be inside the insulation. A code reading session could help.
Steve.
Steve.
not applicable
