My 2006 C5 Exclusive went in for, Clutch, oil change etc. It came back with display flashing so I assume the battery was disconnected. The radio is greyed out in the menu options and it isn’t playing.
It never used to switch off. I presume there is an issue with the on/off button. The manual says that it is paired to the car so there is nothing the driver has to do (ie no code)
Thing is is simply isn’t playing/ Nothing works and being greyed out in the menu I am not sure how to get it working and I can't see why a dodgy on off would have the radio section greyed out in the display. Can anyone give advice?
Getting Radio and CD to work in C5 after work.
boristhespie
- x 4
C'est pas possible!
Clogzz
- x 40
Re: Getting Radio and CD to work in C5 after work.
Disconnecting the battery turns the radio off in a way that it needs switching back on by pushing the switch/volume control knob.
dnsey
- x 19
Once again, you seem to have been let down by your garage, Boris.
Take the car back, and get them to sort it out - they should have taken care to followhe correct procedure when disconnecting and reconnecting the battery, or connected a maintenance supply.
boristhespie
- x 4
Ok fixed. I was trying to take off front panel and simply pulled off the knob. The metal knob underneath works fine. Seems when i push the knob it doesn't push in the metal knob so I put some glue in the bottom of the plastic knob so when I pish this knob it will engage with the metal knob. Now I feel like a nob
C'est pas possible!
- x 1056
Common problem on mk2 C5's, you can buy the button separate.
See here > http://www.frenchcarforum.co.uk/forum/v ... on#p319634" onclick="window.open(this.href);return false;
