ADVICE NEEDED !!!!
sidog70
ADVICE NEEDED !!!!
Unread post by sidog70 »
Sorry guys for harping on about my problem with the abs light, managed to locate a abs ecu for only £100 +vat..
Wanting to know is it just straight forward as removing the connectors off old abs ecu and changing with new or will this need any sought of re-mapping or re-programming as well..
Thanx in advance GUYS
x 1431
As long as it's the right one, it will be a direct plug in.
sidog70
i must admit when i called up the breakers they never asked for any part no or description of abs ecu, just hope now im getting correct one.
The little black box attached onto ecu will that come with new one.????
sidog70
just spoke to breakers they say part is interchangeable is this correct ???
acrowot
Unread post by acrowot »
It can be a bit awkward changeing the ECU, you will have to unplug the connector off the top of the ECU (easy) you then need to remove the two bolts holding the ECU onto the Valveblock ( this is fiddely as the fuse box restricts access to these bolts). There is also a spring clip to release on the bottom of the ECU were it plugs into the Valveblock, when you get the one from the scrappy have a look were this clip is to help in locating the one already in your car, it is underneath the ECU when fitted and not to easy to access. There is no programming required.
sidog70
when you say valveblock is that the plate its bolted on to..
acrowot
The valveblock is the hydroulic part of the ABS system, the ECU plugs in to this(electrically) and is also bolted to it with 2 bolts. The valveblock is bolted to the car, this valveblock has various hydroulic pipes screwed into it, the ECU is the electronic part of the ABS system, and the valve block is the hydroulic part, they are connected and bolted to one another. The ECU is rectangular about 150mm * 100mm in shape about 25mm thick with a connector on the top of it and a connector on the bottom side.The connector on the top connects to the wiring loom to provide the ECU with its power supply and connections from the wheel sensors etc., the connector on the bottom connects the ECU to the valveblock. If your ECU is faulty I am assuming you are only going to change that and not the complete ECU and Valveblock.
sidog70
dont know really just ordered a abs ecu and it cost £100 + vat
noz
Unread post by noz »
sidog70,
Either the other repliees are psychic or I'm stupid. What car are we talking about here? Once established maybe we can help.
regards
noz
acrowot
In the OP,s origional post he said the car was a 1999 Xantia Stateside.
sidog70
Thanx acrowot, sorry noz yes its a 1999 xantia 1.8i stateside...
AndersDK
Unread post by AndersDK »
Stateside ??
- ya mean Estate/stationcar/wagon/Break/Weekend ??
sidog70
Stateside is the model name.
acrowot
Hi Anders
This car seems to be a special edition Xantia Saloon with a 1761cc petrol engine produced oct1998-oct1999
