1989 BX 14E 77k miles
xantiagreen
Unread post by xantiagreen »
Hi, Never owned a 1.4 petrol BX before so want to know if there's any known problems with them please.
Also a few questions.
1. Is this engine cam chain or belt
2. Correct engine oil grade and the best oil to use.
3. Ok to use Forte fuel cleaner / carb cleaner
4. Can the carburettor be computer tuned and is it worth doing
5.whats spark plugs should I use
6. What mpg should I be getting round town and motorway
7. how do I check if the struts/ mounts are ok (77,000 genuine mileage) Do they go bang like on the Series 1 xantia's.
Thanks all.
Faz
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
96 Xantia 2lt 16v Sx Olive green
01 Xantia 110 Hdi
Storm Grey (SOLD 4/11/18)
Temporarily driving Polo 1.9sdi
All I want is a Bx Gti or 16v!
x 94
Re: 1989 BX 14E 77k miles
Unread post by citronut »
depends on its age as the early 1.4 ( pug 104/Visa ) engine with the gear box in the sump, 20/50 mineral oil
and the later ones had the TU ( Saxo and the likes ) lump, 10/40 semi synthetic
the early engine has a timing chain the TU has a timing belt,
the TU is a very easy engine to work on and in the BX you can almost climb in the engine bay with it,
both the early 1.4 and the TU have a basic carb but the later TU has the mono point injection ( looks like a carb to the lay man )
i have never heard of a BX strut top spearing the bonnet,
also you might get more responce over on the FCF's sister forum, although i would suspect your already registered over there
http://www.bxclub.co.uk/forum/ucp.php?mode=login" onclick="window.open(this.href);return false;
Regards, malcolm.
xantiagreen
citronut wrote:depends on its age as the early 1.4
Cheers for the info Malcolm.
Faz
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
01 Xantia 110 Hdi
