c8 economy mode
m300td
c8 economy mode
Unread post by m300td »
hi all I don't know if anyone could help I have a c8 that has a snapped cam belt that I cannot start the problem is it is in economy mode and the windows are down
does any one know which relay drops out when it enters economy mode as I thought that If I bridged this relay I could at least get the windows back up
thanks in advance
malc
lexia owner nr telford
Lighty
x 35
Re: c8 economy mode
Unread post by Lighty »
Have you tried disconnecting the battery, this will sometimes allow you to power them up again (when reconnected)
If not, I took the door panel off a C8 the other day & just powered the motor up with a battery.
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
