I have a 1996 405 SRDT. It has a D8A 1.9 turbo diesel engine. About a week ago I noticed diesel puddles under the engine block. After some time spent in the weekend looking for a leak I discovered the diesel is coming from a small rubber nipple-like pipe on the top part of the fuel delivery assembly attached to the front of the block (home handyman - sorry). When the engine is running this produces about a drop a second - not too good for the fuel consumption!
After reading the Haynes manual, taking off the intercooler, tracing the fuel lines, reading the Haynes manual some more and reading CitroJim's excellent post on replacing injector pump seals (boy that looks ugly) I'm thinking this is the fuel supply pump. Is that right? I can't find out anything about it anywhere but it has a fuel line coming in from the fuel filter and another line out which is presumably the return to the fuel tank. So is this nipple thingy some kind of relief valve? Does that mean a blockage or failure somewhere inside the unit? It has just started to get cold here (NZ) after a very mild autumn so it's the season for O-ring and seal failures.
I've tried attaching a picture to this post but a message says "The board attachment quota has been reached" so I've put it in the public space of my Microsoft OneDrive account instead - https://onedrive.live.com/redir?resid=B ... AD27%21107
The injector pump has 445-3 stamped on it so I'm pretty sure this is a Bosch unit especially seeing as the car is a 1996 model which I think was the last of the 405s. It seems very similar to the unit in CitroJim's post.
All advice and help welcomed. Thanks.
Cheers,
Guy
