806 turbo!!
m300td
806 turbo!!
Unread post by m300td »
Hi could anyone please give me some advice I am getting a lot of blue smoke on startup and gets worse until engine warms up but If I remove the inlet air pipe (which has a lot of oil in it) at the manifold I do not get the smoke so I have put it down to the turbo is leaking oil into the inlet. Had a look under neath and everything is so compact and you cam just see the turbo
Has anyone ever changed one and what is the procedure
Many thanks
Malc
lexia owner nr telford
Lighty
x 34
Re: 806 turbo!!
Unread post by Lighty »
Very difficult job, mostly done from underneath, personally I would take it to a garage .
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
