Citroen Relay Fuel leak
macaroo
- New User
Hi I own a Relay 1100TD 2.0 HDI. on an 05 plate It developed a slight fuel leak so i had it repaired, they said the seals were leaking near the pump. It was fine for a couple of days until the engine management light came on and I lost all power. Fuel was really poring out this time. It went back in for repair and they replaced the seals again but these blew almost immediately . They have come to the conclusion that the fuel pump is faulty and have advised on a new one. Does this seem right and how much should I expect to pay?
macaroo
- New User
Re: Citroen Relay Fuel leak
Cheers loopy. vin details are 17564071. Knowing my luck mine will be the top dollar one!! If so its almost at the stage where is it worth while.....
- x 94
do you know were exactly the pump is leaking ( front, back or middle joint????? ),
i know nout about these pumps but is it possible whoever replaced the seals damaged/cracked the unit ( regulator ) on the rear of the pump,
so it now cant retain the fuel pressure/seals,
if this is damaged here is price and part No. for that
Part Number Description Quantity Price excl. VAT Price incl. VAT Total incl. VAT Selection
0000193338 REGULATOR 294.38 GBP 353.26 GBP 353.26 GBP
Regards, malcolm.
