think I might have overdone it
Bandit12
x 12
Unread post by Bandit12 »
Hi guys, I recently changed the trailing arm bearings on my C5. I did passenger side first and plan on doing the drivers side this month when it finally decides to stop raining:-) I think I may have overtightened the main 24mm bolt that the trailing arm pivots on because I occasionally get what can only be described as a 'crack' similar to a rifle shot or that noise when you crack off a really tight nut when I hit a bump in the road. Only started to notice it last weekend when it was warm enough to have the back windows down while driving. It does seem to be coming from the rear passenger side with the new bearings.
Can anyone tell me the correct torque setting for the bolt and I'll double check I've not been too gung ho with the torque wrench :oops:
Bandit
2002 Citroen C5 2.2Hdi exclusive estate (sadly gone) :(
2009 Citroën C5 X7 2.0 hdi (136bhp) exclusive estate (Oh wow what an upgrade) 8-)
Mandrake
x 694
Re: think I might have overdone it
Unread post by Mandrake »
You didn't leave the bearing pre-loading shim out did you ? It's easy for it to get lost in the process... If it's missing the bolt torque will just be squeezing the bracket on the suspension chassis together but won't actually be putting much (or any) load on the bearings to hold them together...
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
Bandit12
x 12
Hi Mandrake
I put everything that came out back in in the right order using printoffs of citroen doc backup as a guide. By pre load shim do you mean part number 514327 labelled as 'wedges set'? That was the only part that caused me a little confusion.
Bandit
x 94
Unread post by citronut »
Bandit12 wrote:Hi Mandrake
Bandit
yes the wdge set is a packet of assorted shims from the dealer,
although i cant see leaving it out will cause the crack you describe, as the usual crack is caused by the rollers of the bearings being trapped then going passed the wear grooves in the old bearing inner and outer race's,
when the bearing have been in place for a long period of time/miles, they break up and the rollers float about unguided in there track,
as you would have seen on dismantling the one you did,
Regards, malcolm.
Bandit12
x 12
Thanks Malcolm.
I agree with your explanation.
I've made a real effort to find our which side it is and I'm now confident that it is the right hand side which I have not replaced yet. The left hand side disintegrated when I took it apart and looking at the angle of the wheel on the right hand side it is defo sloping \\ All parts are ordered and I plan on doing the job next weekend.
Appreciate the advice and tips guys
Bandit :)
x 94
were and how much did you fork out for the bits,
as i found the cheapest way to obtain quality parts was purchase the bearings and possibly the seals from GSF, as long as they can supply Corteco seals
http://www.corteco.com/en/products/online-catalogue/" onclick="window.open(this.href);return false;
and the spacer tube and bush's from citroen dealer
Stevie ( myglaren ) might be along shortly to point you in the direction of the thread with all the price's and part No.'s
Regards, malcolm.
x 5657
Third post down..
We should bookmark this Malcolm
x 94
i have made it a supper sticky,
but i think that will depend on what grease you choose to apply :shock: :-D :rofl2: :rofl2: :wink:
Regards, malcolm.
