xantia back end collapse
jacksun1987
Unread post by jacksun1987 »
I was driving on way home on nights I am I went over a had the car on sports suspension then I heard this bang every bump was a big smack I got home the back end was down to the ground not pumping up
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Broken dogbone, usually.
KennyW
x 165
Re: xantia back end collapse
Unread post by KennyW »
Agree with addo a broken dogbone
C3 1.4 petrol (SWMBO)
jacksun1987
How much do they cost a're they dear are they hard to-do
I had my car on the active roll suspension when it weMr
And my aerm bearings was going at the back
x 1240
Unread post by Peter.N. »
Very cheap and easy to fit. Not so the radius arm bearings though.
Xantidote
x 4
Unread post by Xantidote »
The dog-bone itself is £3-4 IIRC, and not too difficult to fit, but BE CAREFUL whilst you are working under the car - have it propped on axle stands or blocks of wood. It could alternatively be the metal arm that connects the dog-bone to the anti-roll bar, either broken, or (as in my case a few years ago) the bolt that clamps the metal arm to the anti-roll bar wasn't quite tight enough, allowing the clamp to rotate slightly.
Martin
1995 Xantia TDLX (deceased :( )
jacksun1987
Made the suspension go up and down it goes ok from hight to drive settings but not ok to low to drive settings on drive settings it feel s all hard no bounce LMike there should be and when I switched then engine off it dropped abit
Xaccers
x 188
Unread post by Xaccers »
jacksun1987 wrote:Made the suspension go up and down it goes ok from hight to drive settings but not ok to low to drive settings on drive settings it feel s all hard no bounce LMike there should be and when I switched then engine off it dropped abit
You currently only have manual control over the height because the dog bone is not connected, so the auto height correction cannot work.
DIY sphere tool
jacksun1987
Can I still drive it need it for work can't borrow my mum's car she's on holiday. When the car is on drive mode it won't sink down while going over bumps etc?
c.morewood
x 55
Unread post by c.morewood »
Have a look under the car when is set on high.. don't go under it.. you might just see the "dogbone" hanging down.. it might not be broken, but may have just slipped off its mounting.. in which case you could try, after putting the appropriate axle stands in place, pushing it back on to its ball.
If it pops again you'll probably have to buy a new one and if that pops chances are that the ball has worn down and you'll need another.
I'm running round with a cable tie holding the new dogbone onto the ball as I haven't had time to swap over the height corrector assembly.
Hope this helps.
Tesla Model 3 LR DM AWD Blue White
'00 Xant 110HdiSX Est 83K "W"
'99 Xant 110HdiSX Est 320K "V"
'98 Xant 1.9TDSX Est 150K "T"
'97 Xant 1.9TD 20k Est
'94 Fiat TipoTd 40K
'85 BMW K100RT 330K Garaged 26yrs '80 Honda CB250 twin Superdream
rory_perrett
Unread post by rory_perrett »
Dog bone part number 5291 03 shown as £2.64 inc VAT on Service Citroen. How do I know? For the first time in 20 years of Citroen Ownership my rear dogbone popped off on Sunday. Pushed it back on but it did the same again 20 miles later on Monday morning. Popped it back on again and then put some wire round it to hold it on when I got to work. I would not drive the car any distance at all with it either down on the bump stops or up on the high setting. Not only is it likely to do some damage the car is seriously uncomfortable and to my mind dangerous to drive as any slight bump has it bouncing all over the place. When it came off the 2nd time I was on the motorway and had to drive 4 miles to get off and to a safe place to fix it. I really didn't enjoy that 4 miles at all and certainly wouldn't have wanted to drive any further than absolutely necessary.
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
You might be best asking old-guy for an anti roll bar clamp. Estates have thicker anti roll bars so a hatch clamp wont fit the bar and wont clamp up.. I changed a clamp tuesday morning on a hatch. The rod had broke the dogbone was unharmed.
A very sad...
1994 XM 2.1 d auto
jacksun1987
i need the car for tonight. Got no other option. I drove it up and down the drive breaking heavy. Seem to stay up. But theres no feel in the suspension feel rock hard. And its stayed up for 3 to 4 hours.. But if i put it to low to driving mode. The back end does not go up
citroenxm
Fallen Hero
x 70
Xantia suspension ALWAYS stays up on top even when braking!
However, it will drop when on driving position. Rear brakes work through the brake valve, and pressure is always released from the rear when the pedal is pressed...
A very sad...
1994 XM 2.1 d auto
jacksun1987
its on driving setting now it still stayed up.
Low setting to driving setting the back end doesnt even move
Highest setting to driving setting it seem to have stayed up on its own.
When i turned the engine off the front end dropped
