C5 heater
daviemck2006
x 496
C5 heater
Unread post by daviemck2006 »
My heater is being weird. I don't think it's the usual c5 problem of the box of tricks beside the clutch pedal. The drivers side won't change the heat setting it seems to be whatever the outside air temperature coming through whatever the temperature is set at, whilst the passenger side is working perfectly. It'ssuper cold here tonight and with both sides set at 22 drivers side blowing cold and passenger side nice and warm. Outside temperature showing 5. I seem to remember something about flaps sticking but can't find the info. Can anyone help on where to find them and how to fix them?
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
waynedance
x 8
Re: C5 heater
Unread post by waynedance »
http://www.frenchcarforum.co.uk/forum/v ... eater+flap" onclick="window.open(this.href);return false;
This refers to the passenger side but I guess the drivers would be the same, search C5 heater flaps will bring up plenty of posts.
Volvo S80 D5.........
hamster99
Re: C5 heater
Unread post by hamster99 »
Hi Davie
Lots of us on here have come up against this problem with the heater temperature flaps.
Citroen do a replacement flap set for around £65 but the hassle is in fitting them. Some say you can cut out the side of the unit but thats really only possible on the passenger side and is a lot of fiddling around. Alternative is then to remove dashboard. That's what I did and it's not as bad as you may think and there are some shortcuts you wont find in the Haynes manual (oh what a surprise!!!)
Take a look at the posts below (and any others you can find) and then maybe come back with your thoughts. Bear in mind also that the C5 & 407 have the same heater unit.
Don't despair...there is an answer out there!
Rob
http://www.frenchcarforum.co.uk/forum/v ... =3&t=48324" onclick="window.open(this.href);return false;
http://www.aussiefrogs.com/forum/citro" onclick="window.open(this.href);return false;% ... otors.html
http://www.citroen-owners-club.co.uk/ci" onclick="window.open(this.href);return false; ... itroen-c5/
http://www.citroen-owners-club.co.uk/ci" onclick="window.open(this.href);return false; ... 02-aircon/
http://peugeot-407-heater-fix.weebly.com/" onclick="window.open(this.href);return false;
22 C4 1.6 eHDI Shine Plus
67 RR Autobiography 4.4 SDV8
15 C4 1.6 eHDI 115 Exclusive - fond memories
12 RR Westminster 4.4 TDV8 - Gentleman's Club on wheels
05 C5 2.0 HDI 138 Exclusive - gone but not forgotten
05 C5 2.0 HDI 138 VTR - crushed May 2015
daviemck2006
x 496
Re: C5 heater
So this looks like it's gonna be a total pain in the butt. I have searched a few now and the passenger side seems to be doable through the glove box, it's the drivers side that I have got gone which looks very like a dash out job, and may well be the reason the car was ultra cheap. I won't be doing that personally. I'm usually in car myself and can get it heating up just with pass side on max, but that'snot Iin winter time. Mmmmmmmmmmmmm decisions.
Peugeot boxer 2016
In the family
x 3283
Re: C5 heater
Does the C5 have heated seats? If not, every so often Lidl or Aldi do car bits, which can include heated seat cushions. I will PM you (as well as post up the details on my relevant thread) the next time either of them do.
daviemck2006
x 496
Re: C5 heater
Im going to have a look to see if I can swap the air hoses going to the footwells. If I can then it's a bodge but will give me heat :) I was going to be on the lookout for heated leather so will I spend on leather or fixing the heater properly? Depends on if the bodge works or no!
Peugeot boxer 2016
In the family
triumphtoledo
Re: C5 heater
Unread post by triumphtoledo »
So do tell what are the shortcuts??
hamster99
Re: C5 heater
triumphtoledo wrote:So do tell what are the shortcuts??
Have replied to your PM
Rob
triumphtoledo
Re: C5 heater
Thanks for this; I ended up doing it the 'proper way'; with the dash and heater box coming out.
It was surprisingly logical and easy really. I stripped the heater box, cleaned the existing flaps and the whole box moulding, lubricated the distribution flaps (and the new heater flaps), cleaned out the mouldy evaporator and put everything back together. Even better, it all works. Yay!
The main tip that I benefitted from is there being no need to remove neither steering wheel nor airbags. The column is only held in by 3 bolts (plus the UJ nut and bolt).
So, don't be scared of the job really. I found it great to work on the heater box in my warm garage, rather than spending hours crouched in a footwell, trying to cut into its side, which has been suggested.
The job is going to be covered in Car Mechanics magazine soon, so spread the word!
R
hamster99
Re: C5 heater
Glad to have helped out on this (especially the steering column and airbag tip which I discovered when I did mine)
Sharing information and tips is what the forum is all about.
Cheers
Rob
daviemck2006
x 496
I'm waiting until MOT is passed hopefully on Tuesday first time before I think about the heater box. Funds are tight so it will depend on how much cash it takes for the test.
Peugeot boxer 2016
In the family
BigBadBob
Re: C5 heater
Unread post by BigBadBob »
Can you give us an idea of how long it took to complete the job?
2006 1.6 HDI C5 VTR Estate
hamster99
Re: C5 heater
It took me around 3 days because I was swapping the heater box from one car to another but the actual dash and heater box removal, repair and refitting could easily be done over a weekend, especially once I discovered you don't need to strip out the airbags and disassemble the steering column. That alone would have taken at least another 4 or 5 hours.
It sounds daunting, especially if you read it in the Haynes manual, but as long as you're handy with a set of tools it's not that difficult.
Rob
KP
x 27
Re: C5 heater
Unread post by KP »
Do you know which issue it's going to be in as I'd like to buy it to help me and my dad out as picture always help :)
triumphtoledo
Re: C5 heater
Not sure which issue of the magazine it will be in, as it depends on the editor's schedule. Possibly within the next 2-3 months.
I'll send the text and image to him later today. - I'm just doing a final sub-edit.
The job took me a weekend - but that included doing the photography as well - and it was my first time doing it.
Basically, it's lots of small, easy stages, not one single nightmarish one. The other tip I can recall is label the small heater box wiring loom, so everything is refitted in the same order.
R
